Playing audio file after transfer, dial by name directory...
Discussion in '3CX Phone System - General' started by aether, Aug 13, 2014.
  1. aether
    Aug 13, 2014
    I am trying to figure out how to play an audio file that says "this call may be monitored or recorded for quality assurance purposes". I have found a way to play this after a queue call is routed. But is it possible to have the file played if someone dials a user extension off the digital receptionist? What about before the call is transferred after accessing the dial by name directory?
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Re: Playing audio file after transfer, dial by name director
    Hi there,
    You could look into replacing the "Please hold while I transfer your call" audio file, and record a new one with your own prompt in place, file is located in C:\ProgramData\3CX\Data\Ivr\Prompts\Sets\8210986B-9412-497f-AD77-3A554F4A9BDB\please_hold.wav
    Watch out file format must remains the same (8000 Hz, 16-bit, Mono, PCM-encoding, WAV format).
