Playing with ... "Please hold while I transfert your call"
Discussion in '3CX Phone System - General' started by DomoJP, May 27, 2010.
  1. DomoJP
    Mar 11, 2010
    6
    We've got an installation which has IVRs in French, but they also have English customer.
    Their IVR start with stating that :
    "If you need english support, please press 9"
    If you dial 9, it'll tell you "Veuillez patientez pendant que je transfert votre appel..." ("Please hold while I transfert your call" in french).
    Is there a way to do either of these options :
    Have only the English IVR Play the "Please_Hold.wav"
    Have both the English and French "Please_Hold.wav" play
    To completely and EFFICIENTLY remove the "Please_Hold.wav"
    I'm saying Efficiently cause after looking at some of the post with my searchs, they're submiting way to fix what I ask but none worked, or the path dont exist, or it crashed totally my system.
    I've tryied replacing the "Please_hold.wav" in my "Sets" by something empty, crashed the system, the IVR system wouldnt reboot.
    Well I've tried many stuff and didnt work :p
    Our installation is on a Windows Vista Home Premium.
    Thanks a lot :)
    DomoJP!
    10,357
    224
    I don't know if this (your version) has anything to do with your crash issues or not.
    http://www.3cx.com/blog/docs/supported-windows-versions/
  3. DomoJP
    Mar 11, 2010
    6
    Well I said it was our installation because I'm likely to try it on my system before implementing it on a client installation....
    If thats really the matters of why I don't get support, know that the original computer/server where it is going is on XP Pro.
    Any hints please ? :)
  4. leejor
    10,357
    224
    Have you tried replacing the .wav file with a legit file recorded to 3CX specs?
