Please can someone elaborate/explain this Server Event Log
Discussion in '3CX Phone System - General' started by ivan308, May 20, 2011.
  1. ivan308
    May 9, 2011
    6
    I got the following messages in my Server Event Log.
    I am not sure where the issue is. Who/What is forbidding the call. Is this an issue with the provider ?
    Code:
    Call to 13216521555@(Ln.10002@Vitelity) has failed. [ V4 64.2.142.216:5060 UDP target domain=unspecified mFlowKey=792 ] replied: 403 Forbidden; from IP:64.2.142.216:5060
    Call to 12153684976@(Ln.10002@Vitelity) has failed. [ V4 64.2.142.216:5060 UDP target domain=unspecified mFlowKey=792 ] replied: 403 Forbidden; from IP:64.2.142.216:5060
    Call to 13214800086@(Ln.10002@Vitelity) has failed. [ V4 64.2.142.17:5060 UDP target domain=unspecified mFlowKey=792 ] replied: 403 Forbidden; from IP:64.2.142.17:5060
    10,573
    247
    Re: Please can someone elaborate/explain this Server Event L
    You may want to check how you have the Vitelity domain (SIP server info) name put into the trunk datafill in 3CX. It usually is more than just the one word, should be something like xxx2.vitelity.xxx ,as the server name
  3. ivan308
    May 9, 2011
    6
    If you are referring to the SIP server hostname or IP it is already populated with sip18.vitelity.net
    Is there some other field "Trunk Datafill" ?
