Please Fix broken implementation of SRV record handling
Discussion in 'Ideas' started by Elliott, Oct 12, 2017.
Please Fix broken implementation of SRV record handling 5 5 19votes
5/5, 19 votes
  1. Elliott
    Oct 11, 2017
    So I logged a support case with 3CX about this and was told it was expected behavior and I needed to submit a feature request... This was originally a request to support SIP OPTIONS for monitoring SIP server health, but actually just supporting SRV record lookups as per the SIP RFC would be a start.
    So here goes:
    3CX does not support SRV records properly.
    From RFC3263: Session Initiation Protocol (SIP): Locating SIP Servers
    4.3:
    For SIP requests, failure occurs if the transaction layer reports a 503 error response or a transport failure of some sort (generally, due to fatal ICMP errors in UDP or connection failures in TCP)... If a failure occurs, the client SHOULD create a new request, which is identical to the previous.... That request is sent to the next element in the list as specified by RFC 2782 [The next SRV record]
    Instead, 3CX does the following:
    It looks up the SRV record, attempts with the highest priority record, but if a failure occurs (or this server is down) 3CX fails the call. Subsequent calls will continue to use the non-working SIP Server from the SRV record randomly, even if there are other servers with lower priority (backups).
    This makes implementing redundant SBC's/SIP Servers a manual process of adding the trunk multiple times. We have (had) a planned rollout of hudreds of 3CX instances and the inability of 3CX to support DNS fail-over, a pretty essential part of the SIP protocol design, basically makes this a deal breaker.
    And a warning to anyone using SRV records for 3CX: If you have an SBC/SIP server failure, your calls WILL NOT work reliably outbound until this basic functionality is fixed.
  2. accentlogic
    accentlogic New Member
    Nov 14, 2013
    160
    66
    This has been confirmed to us by a 3CX certified SIP provider. I love the concept, it just needs to work reliably and would simplify many installations or make them more robust. Feel free to PM me for details.
  3. Sopock
    Sopock Member
    Jul 11, 2012
    448
    20
    That could also help in this scenario instead of relying on TTL values and updating the IP of same FQDN?
    https://www.3cx.com/community/threads/failover-on-enterprise.51324/
  4. Elliott
    Oct 11, 2017
    Bump :)
    Sorry Sopock, for us manual DNS intervention is not a replacement for SRV (which works flawlessly when implemented as per the RFC, which 3CX has not followed)
    Really wanting you guys to implement this so we can roll this out to dozens of customers...
  5. cobaltit
    cobaltit Active Member
    Mar 22, 2012
    733
    112
    BUMP
    Running into this concern now as well. Did you make a feature request already?
  6. cobaltit
    Mar 22, 2012
    733
    112
    Ignore the feature request part, I just realized this post was in the ideas section
  7. cobaltit
    Mar 22, 2012
    733
    112
    @Elliott
    Have you tested this since the SP2 release? I don't see anything in the notes about it but hoping it is working.
    Also, per this post 3CX has joined the SIP Forum as a full member and is going to take the SIPconnect certification test. Unless I'm reading it wrong, supporting SRV records per the RFC is a requirement to be SIPconnect v1.1 certified so hopefully they are working on it and it's not considered a feature request so much as a requirement.
  8. Elliott
    Oct 11, 2017
    Hey,
    So I haven't tried it specifically but I did go through the release notes and there is nothing about it in there.
    It became a huge issue with us and we ended up having to redesign our SBC deployment to fit this problem.
    3CX came back to me and said it's a feature request rather than a bug, which makes zero sense for a supposed "standards based" PBX, so lets hope the SIPConnect thing makes them pick up their game!
  9. Miggidy
    Jan 29, 2018
    Has this bug/feature been fixed/implemented yet?
    It's pretty poor form this is even considered a feature request by a serious software provider.
    josea and DrewHammond like this.
  10. bbaker73
    bbaker73 New Member
    Nov 27, 2015
    106
    18
    Guys, is this the same issue I experienced with a voip provider a few times the last few days? They have gw.sipprovider.com, gw1.sipprovider.com, gw2.sipprovider.com. Our trunks are registered with gw. and provider says they have SRV record. They had an outage and all of our trunks for all of our clients went down for 10+ minutes. Along with emails for trunks not registed, 3CX servers also sent:
    Registration at SIPTRUNK has failed.
    Destination (sip:12345678@gw.sipprovider.com:5060) is not reachable, DNS error resolving FQDN, or service is not available.
    Sip provider says only 3CX customers had issues during the problem as gw2. was up and processing calls the whole time. Based on this, their recommendation is to dual register gw1 and gw2 trunks with them and instead of using gw. Seems this is a workaround and a LOT of added work to put multiple trunks for each of our clients (each with 2-10 trunks now) and modify multiple outbound rules with backup route as well.
    Miggidy likes this.
  11. Miggidy
    Jan 29, 2018
    Yep, same issue. 3CX need to fix SVR or they are going to start losing customers. We are certainly looking at alternative options already.
  12. josea
    Sep 13, 2017
    23
    5
    We were also affected and got the same recommendation. Which is okay coming from the trunk provider but it is a waste of time. This should be fixed in the 3CX software...
    Miggidy likes this.
  13. bbaker73
    bbaker73 New Member
    Nov 27, 2015
    106
    18
    Maybe you guys can answer this without a lot of testing on my end. If I do set up a backup trunk with provider, do I specify the same DID's on both trunks, and since DID's are specified per trunk and inbound rules in 3CX, do I have to create a 2nd duplicate set of inbound DID's rules for the new trunk to match the other trunk, in essence having two sets of rules for the same DID? Seems like I remember when switching voip providers some time ago, we did create a duplicate inbound rule set, but found 3CX matched the first rule for the DID regardless of the trunk it came in on.
  14. bbaker73
    bbaker73 New Member
    Nov 27, 2015
    106
    18
    I'm finding in testing adding 2nd backup trunk to provider, that I DO have to set up duplicate inbound rules/DID for each trunk for calls to route. :( Even with import/export of Inbound rules and modifying it in bulk to add the rules for the 2nd truck, it's still too much work. I have clients with hundreds of DID/Inbound rules. There has to be a simpler way to work with multiple trunks from the voip provider.
  15. 3CXDude
    Oct 1, 2015
    94
    23
    Its a very poor show from 3CX on this in my opinion.
    Given the fact that this thread has been ongoing for 6 months and there has not even been a response, says it all really.
  16. cobaltit
    Mar 22, 2012
    733
    112
  17. TP_
    TP_
    May 15, 2018
    26
