please helo with configuring dialing AFTER call is made
Discussion in '3CX Phone System - General' started by Mioduz, Jun 20, 2008.
  1. Mioduz
    Mar 12, 2008
    19
    I set up a new VoIP system with 3CX in my house. I am using a Linksys SPA 942. My current issue is when I place a call, and an automated attendant answers and I need to "press 1 for English" My phone does not let me. If I press the 1 button, a tone is emitted but it seams like it is not getting through to the other end of the call. Any help?
  2. cpinero
    Apr 26, 2008
    12
    I'm having the same problem. I found out that if you change the DTMF Tx Methond in the Ext1 menu of the SPA942 to Inband and do not use the speakerphone the DTMF tones should work. I have not been able to use the DTMF using the speakerphone.
