PLEASE help! All phones now unregistered
Discussion in '3CX Phone System - General' started by semtex65, Mar 24, 2012.
  1. semtex65
    Feb 23, 2012
    18
    Hi Guys,
    About 3:30 this morning, my Windows Server 2008R2 decided to install updates and restart. Prior to this, everything was working fine. And then this appeared in the server logs...
    http://img26.imageshack.us/img26/23/eventlog.jpg
    This morning, I removed the updates that were installed (sorry i forgot to note what they were, though some were .NET), as this is the only thing that had changed - the system was working faultlessly prior to this.
    Things have changed a little since then... this is from the event log, having just re-started the server and all phones..
    10:46:30.790 [CM504001]: Ext.EndCall: new contact is registered. Contact(s): [sip:EndCall@127.0.0.1:40600;rinstance=dc84aa83dc2f8e28/EndCall]
    10:46:30.785 [CM504001]: Ext.800: new contact is registered. Contact(s): [sip:800@127.0.0.1:40600;rinstance=4b74dbeebdeef6ea/800]
    10:46:30.784 [CM504001]: Ext.777: new contact is registered. Contact(s): [sip:777@127.0.0.1:40600;rinstance=43e0f163cc8a9f17/777]
    10:46:26.960 [CM504001]: Ext.*1: new contact is registered. Contact(s): [sip:*1@127.0.0.1:40000;rinstance=88ff44a4bea9a51e/*1]
    10:46:26.959 [CM504001]: Ext.*0: new contact is registered. Contact(s): [sip:*0@127.0.0.1:40000;rinstance=cbe7614bd0265762/*0]
    10:46:26.849 [CM504001]: Ext.*777: new contact is registered. Contact(s): [sip:*777@127.0.0.1:40000;rinstance=84fa0c6899f61202/*777]
    10:46:21.555 [CM102001]: Authentication failed for SipReq: REGISTER 192.168.51.132 tid=f827636c7a15e80b cseq=REGISTER contact=DialCode@127.0.0.1:5488 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    10:46:21.206 [EC100007]: External application is connected: application:SVR01:0/QueueManager local:127.0.0.1:5482 remote:127.0.0.1:49238
    10:46:18.645 IP(s) added:[192.168.51.100]
    10:46:17.778 [EC200005]: Parking Orbit server is connected: application:SVR01:0/3CXParkOrbit local:127.0.0.1:5482 remote:127.0.0.1:49224
    10:46:17.594 [CM504008]: Fax Service: registered as sip:888@192.168.51.100:5060 with contact sip:888@192.168.51.100:5100;user=phone
    10:46:17.445 [EC200002]: Media server is connected: application:SVR01:0/MediaServer local:127.0.0.1:5482 remote:127.0.0.1:49223
    10:46:17.119 [EC200004]: IVR server is connected: application:SVR01:0/IVRServer local:127.0.0.1:5482 remote:127.0.0.1:49222
    10:46:15.056 [EC200006]: Conference server is connected: application:SVR01:0/3CXConferenceRoom local:127.0.0.1:5482 remote:127.0.0.1:49218
    10:46:10.207 [CM506005]: Public IP=xxx.xxx.xxx.xxx is used for WAN communications through local interface with IP=192.168.51.100
    10:46:08.847 Failed to obtain short path name for [C:\ProgramData\3CX\Bin\Cert]
    10:46:08.847 [CM501006]: Default Local IP address: [192.168.51.100]
    10:46:08.797 [CM501002]: Version: 10.0.23053.0
    10:46:08.797 [CM501001]: Start 3CX PhoneSystem Call Manager
    10:46:08.797 [CM501010]: License Info: Load Failed - Error licence Licence: 27 System: 2
    10:46:08.650 [CM501007]: *** Started Calls Controller thread ***
    10:46:08.627 [EC200001]: Configuration server is connected: application:SVR01:5485/DBProvider local:127.0.0.1:49216 remote:127.0.0.1:5485
    As you can see, none of the phones are connecting - there's 10 of them, all runing on extensions 100, 101, 102 etc...
    Can anyone shed any light on why this has happened and how to fix? Really need to sort this before the office re-opens on Monday. help!
    Thanks in advance to anyone that can help.
  2. semtex65
    Feb 23, 2012
    18
    OK, we can scrap that one now. Took a configuration backup, uninstalled 3CX, restarted the server, reinstalled 3CX, loaded in the configuration backup and all is working again.
    Very strange though, would still like to know what caused it.
  3. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    The only isssue I could possibly think of is an IP address, was this something your checked in customer parimenters, on all the phones, and the server before restoring the backup?
  4. semtex65
    Feb 23, 2012
    18
    Yep, I check IP's and that the (Cisco) phones were pulling their configs from the TFTP server, which they were. I'm just completely at a loss as to why it happened, because not even the smallest detail or parameter has changed anywhere on the network.
