- Joined
- Mar 12, 2008
- Messages
- 19
- Reaction score
- 0
I installed a sipura spa-3000 with the intent to use it as a gateway.
I have been unsuccesful at getting the device to register with 3CX
Server log:
18:37:43.594 AuthMgr:nAuthFailure [CM102001]: Authentication failed for SipReq: REGISTER 192.168.1.10 tid=-747c0a70 cseq=REGISTER [email protected]:5061 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
18:37:43.281 printDetailedInfo [CM502001]: Source info: From: "5707543230"[sip:[email protected]];tag=9c2da34bb241706co1; To: "5707543230"[sip:[email protected]]
18:37:43.281 evt::CheckAuth::not_handled [CM302002]: Authentication failed due to unidentified source of: SipReq: REGISTER 192.168.1.10 tid=-747c0a70 cseq=REGISTER [email protected]:5061 / 2 from(wire)
Apparantly it thinks I have the wrong ID and password. I followed the 3CX configuration page to set up the device. I have triple checked to make sure that both the auth ID and Pass are set correctly, as well as "Use authID" is set to yes.
Anyone have any advice
Server log:
