Please Henk some help!
Discussion in '3CX Phone System - General' started by mujalli, May 26, 2007.
  1. mujalli
    Jan 31, 2007
    25
    Hi Henk or some forum friend,
    Coul you help me a bit once I to configure a static IP on the WRT54GS,
    how to (WRT54GS) configured it to forward the request to the 3cx Server?
    HOw WRT54GS, use port forwarding to forward the requests to the 3cx server?
    Thanks, mujalli
  2. Anonymous
    Anonymous Guest
    Hmm, you are lucky that i am wearing my "superman3 undies" :).
    Let me see how this goes.
    Static IP you need to get from your ISP i you want to use that to get into your WRTS4GS, that is the WAN IP address.
    For internal network you can configure which ever one you want, but make sure it is part of the "non" routable IP address just to be save.
    (eg. 192.168.x.x)
    Portforwarding of a http is like this:
    http://www.portforward.com/english/routers/port_forwarding/Linksys/WRT54GS/HTTP.htm
    Mighty handy site that one, the port you are forwarding to is the IP address of the 3cx server with the ports you have configured as your SIP ports most likely 5060. (enter this for you start and end port)
    Hope this helps.
    H.
  3. mujalli
    Jan 31, 2007
    25
    Thanks a lot superfriend man 30...
