Ploblems creating extensions after restoring a backup.
Discussion in '3CX Phone System - General' started by beaver, Jan 3, 2008.
  1. beaver
    Aug 2, 2007
    30
    I restore a backup from version 3 in version 4 and 5 but after that i tried to make a new extension adn the system prompt
    Cannot save DN object: ERROR: duplicate key violates unique constraint "dn_pkey"<br>#0 C:\Program Files\3CX PhoneSystem\Data\Http\functions\CallContext.php(94): safeExec(Object(PDOStatement), 'Cannot save DN ...')<br />
    #1 C:\Program Files\3CX PhoneSystem\Data\Http\functions\fDN.php(162): CallContext->safeExec('insert into dn ...', Array, 'Cannot save DN ...')<br />
    #2 C:\Program Files\3CX PhoneSystem\Data\Http\functions\fDN.php(121): fDN::saveDN(Object(oDN))<br />
    #3 C:\Program Files\3CX PhoneSystem\Data\Http\functions\fExtension.php(112): fDN::save(Object(oDN))<br />
    #4 C:\Program Files\3CX PhoneSystem\Data\Http\functions\fUser.php(41): fExtension::save(Object(oExtension))<br />
    #5 C:\Program Files\3CX PhoneSystem\Data\Http\user_extension_info.php(1046): fUser::save(Object(oUser))<br />
    #6 C:\Program Files\3CX PhoneSystem\Data\Http\functions\gui\fmPage.php(70): aOnOk->execute()<br />
    #7 C:\Program Files\3CX PhoneSystem\Data\Http\functions\gui\fmPage.php(85): fmPage->processData()<br />
    #8 C:\Program Files\3CX PhoneSystem\Data\Http\functions\gui\fmPageEx.php(110): fmPage->toHTML()<br />
    #9 C:\Program Files\3CX PhoneSystem\Data\Http\user_extension_info.php(1096): fmCustomPage->toHTML()<br />
    #10 {main}
    Please help.
  2. Pentangle
    Pentangle Member
    Dec 6, 2007
    261
    Have you tried restoring the v3 backup, then immediately taking a new backup, uninstalling, reinstalling, and then restoring the new backup?
  3. beaver
    Aug 2, 2007
    30
    restore backup restore
    I try what you said but the problem persist. Anyone, help.
  4. beaver
    Aug 2, 2007
    30
    Looks that is working now
    Ok that's what i did. I follow the recomendation of the reply, but it didn't work. after that i delete all the extensions, and restore the backup again and there is were everithing start to work again.
