Pls. support Fanvil Provisioning in V15
Discussion in 'Ideas' started by ASI5, Jan 1, 2017.
  1. ASI5
    Jan 1, 2017
    Please return phone provisioning for Fanvil C62, C58 and others just like it was in 3CX V.14.
    Customers that has upgraded to V15 will be forced to replace existing phones or do manual configuration of phone - this even will not guaranty other features like phone-book synchronization, CTI, and so on
  2. alfa4
    Oct 2, 2013
    15
    Hi ASI5.
    As I have favoured Fanvils for my customers and for internal use, they only way is to create a custom template (which is very easy) and you're good to go.
    Just copy the template frpm v14 and throw it inside v15 as a cuatom template. Just make sure you go through the xml and see if anything needs to be modified.
    It shouldnt take you more than 10 min from start to finish.
  3. ASI5
    Jan 1, 2017
    Hi Alfa4,
    That was great. I'll try it out.
