Solved PLSHOLD wont change to empty.wav
Draax
I used different browsers but still no success in changing the file.
After selecting the empty.wav and press open the browser does some quick refresh but the please_hold.wav are still selected.
Thanks for any input.
Johan
Hi Johan,
Is your file setup as the following info on our web page;
http://www.3cx.com/docs/converting-wav-file/
One other thing to try if you have not done so already is to copy another file that already exists on the system and use that to see if you are getting the same results.
Please update the post on your findings and if you managed to solve the issue we would be grateful if you could share it with the community.
Regards
Hi MRM!
Thanks for your respons, the file im trying to use is the one that came with the installation at "C:\ProgramData\3CX\Instance1\Data\Ivr\Prompts\empty.wav"
I tried multiple 3CX system files still the same issue "quick refresh"
Johan
Johan,
What I did was rename the please hold file to please hold2 & copied the empty.wav file to the same directory as please hold & renamed that to please hold, then I had to restart the PBX and it worked.
Regards,
Thanks!
It works just fine now.
I have used different PBX's before but 3CX seems to very simple and stable we're going to evaluate the software more and then looking into signing up as a partner.
Johan
Thanks for getting back to us & look forward to working with you in the future.
Get 3CX - Absolutely Free!
3CX
