Plugin Creation
Discussion in 'CRM / Helpdesk / App Integration' started by thatComputerGuy, Sep 6, 2017.
  1. thatComputerGuy
    Sep 6, 2017
    Hello, I don't use this software but a friend of mine does and wanted me to make a plugin for them, while looking at your documentation i made the plugin but can not seem to integrate it in the 3cx software, https://www.3cx.com/docs/crm-integration/#h.b74ai6jxzubp it says there is a place for integration but i do not have that, i was wondering if i potentially downloaded the wrong version or if i did something wrong in general.
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,341
    535
    Hello @thatComputerGuy
    What version do you have? You can see build number on the dashboard under the information column. Next to the licence info there should be a build number.
  3. thatComputerGuy
    Sep 6, 2017
  4. YiannisH_3CX
    May 10, 2016
    7,341
    535
    Your version is the latest so the CRM integration should be in settings / CRM Integration.
    If you cannot see it i would recommend changing your browser or clearing your cache to rule out a display issue.
