Plugin for browsers to make a call
Discussion in 'Windows' started by llondono, Feb 16, 2016.
  1. llondono
    Jun 11, 2015
    6
    A plugin that would work with the browsers such as IE, Firefox that you can highlight/ select and then it will call using CTI or 3CX phone
  2. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,255
    63
    I think you could do that right now as well. In the 3CXPhone app you can go to the menu and then "Hot keys" menu and enable the "Copy number to clipboard" and select a key combination (I have Ctrl + F11).
    Now once you highlight a number somewhere and you press the combination, this number will be copied and pasted into the 3CXPhone app, so all you need to do to dial at this point is press the Enter key.
  3. Frank D
    Frank D New Member
    Oct 6, 2014
    215
    6
    Hi Nick,
    Sortcuts work very nice, but only with power users.
    I think I did setup some TAPI browser plugin once, but I am not sure, if it would still work on V14.
    A browser pluging would be a more direct and visible way to offer this functionality.
