Plugin that exposes an HTTP endpoint
Discussion in 'CRM / Helpdesk / App Integration' started by Daniel Dumitrache, Jan 18, 2018.
  1. Daniel Dumitrache
    Jan 18, 2018
    I'm trying to create a custom plugin that exposes a simple REST service endpoint and a few operations available from there.
    The sample code provided here https://www.3cx.com/blog/docs/3cxphone-for-windows-api/ does that using named pipes, although for the specific use case I need it named pipes are not helping.
    A slightly modified version of the sample code would look like this:
    var binding = new BasicHttpBinding();
    var baseAddress = new Uri("http://localhost:5002/CustomCallService");
    _serviceHost = new WebServiceHost(this, baseAddress);
    _serviceHost.AddServiceEndpoint(typeof(ICallTriggerService), binding, baseAddress);
    _serviceHost.Open();
    Is there a reason why the http://localhost:5002/CustomCallService URL in this case doesn't return any response?
    Thank you.
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,609
    126
    Hello @Daniel Dumitrache,
    This is a programming question, not related to the 3CX API. You're trying to communicate between 2 processes using an IPC channel, you will need to deal with that yourself, or ask your question in a programming site like stackoverflow...
    Kind regards.
