"+" Plus sign does not get detected by Outbound Rule
Discussion in '3CX Phone System - General' started by sanketgroup, Oct 13, 2014.
  1. sanketgroup
    Jun 28, 2012
    97
    Hello
    Many of my users are using 3cx Android App. On their mobile phone book almost all numbers are saved with "+" sign.
    Means "+ and (country code)"
    e.g +91xxxxxxxxx, +44xxxxxxxx, +1xxxxxxxxx
    Now when they directly dial from 3cx android phone via phonebook, 3cx server does not recognize "+" sign.
    I have created outbound rule which says "Calls to Numbers starting with prefix set as "+" (without quote ")
    Whenever user try to dial number with (+) sign, 3cx logs says no outbound rule found. and user not able to make calls.
    Why 3cx does not recognize (+) sign. Now a days in computer CRM or Mobile phonebook, numbers are always saved with international county code format. which is ( + country code)
    pls let me know how do i resolve this issue.
    thanx
    11,116
    329
    You need to set-up e164 processing. See the end of this post...
    http://www.3cx.com/forums/outbound-rules-with-solved-16569.html#p84305
