Pointing a Phone number twords a Remote Phone
Discussion in '3CX Phone System - General' started by tazz, Oct 18, 2007.
  1. tazz
    tazz New Member
    Sep 12, 2007
    124
    Here is the Challange. I'm Pointing a Phone number twords a Remote extension. The Extension shows regestration and as well rings. The party placing the call just hears continuing ringing after the phone is answered. very strange
    Thoughts?
  2. bhavank
    bhavank New Member
    Apr 24, 2007
    109
    Have you configured the firewall on the 3CX system or the firewall server behind which you have your 3CX system. Please check the following link to know more about the firewall ports required by 3CX.
    http://www.3cx.com/forums/categories-1/3cx-phone-system-general-1/the-portforwarding-faq-hope-this-gets-a-sticky-1697/?highlight=ports+sticky
    I hope this will sort out your problem for sure.
  3. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    Hi Tazz, you are an old hand at this. If its giving you a headache it can't be simple. Don't keep secrets, give us some info. What are you using for the remote? Maybe some logs from 3CX? Can the remote make calls outbound via 3CX? Will it receive calls from other extensions? That sort of stuff. Now, I don't promise I can help, I spend most of my time learning from everyone :wink: . But you are sure to get help from someone.
  4. tazz
    tazz New Member
    Sep 12, 2007
    124
    I have 3CX and the remote phone on DMZ. Yes the remote phone can dial out just fine to the PSTN. When I place a call from the Remote to the LAN of the 3CX the LAN phone rings, when answered neither party can hear each other. This is the same when calling from one remote to another, again it will ring but when answered no audio..
  5. bhavank
    bhavank New Member
    Apr 24, 2007
    109
    please post some server status logs for the call being made or received which will help to know the issue.
  6. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    SOURCE_INVITE->PBX->INVITE_TO_OTHER_PARTY
    OK_TO_SOURCE<-PBX<-OK_FROM_OTHER_PARTY
    ACK_OF_SOURCE->PBX->ACK_TO_OTHER_PARTY
    This "chain" can be broken at any stage...
  7. tazz
    tazz New Member
    Sep 12, 2007
    124
    Here is two try's
    14:01:01.093 CallConf::Rejected [CM103005] Call(397) is rejected: Destination is not answering
    14:01:01.093 StratInOut::eek:nCancel [CM104008] Call(397): Call from Ln:10001@SipNumber to 1006 terminated; cause: 408 Request Timeout; internal
    14:01:01.093 CallTarget::create [CM005001] Forward loop detected for destination 1006Forward history:{1006}
    14:00:28.625 CallConf::eek:nIncoming [CM103002] Call(397): Incoming call from 5635571238 (Ln:10001@SipNumber) to sip:6413092822@sipnumber.net
    13:58:59.687 CallConf::Rejected [CM103005] Call(396) is rejected: Destination is not answering
    13:58:59.687 StratInOut::eek:nCancel [CM104008] Call(396): Call from Ln:10001@SipNumber to 1006 terminated; cause: 408 Request Timeout; internal
    13:58:59.687 CallTarget::create [CM005001] Forward loop detected for destination 1006Forward history:{1006}
    13:58:27.109 CallConf::eek:nIncoming [CM103002] Call(396): Incoming call from 5635571238 (Ln:10001@SipNumber) to sip:6413092822@sipnumber.net
  8. tazz
    tazz New Member
    Sep 12, 2007
    124
    Hre is more::
    14:11:06.468 StratLink::eek:nHangUp [CM104001] Call(403): Ext.1001 hung up call; cause: BYE; from IP:12.219.100.176
    14:11:02.796 CallLegImpl::eek:nConnected [CM103001] Call(403): Created audio channel for Ln:10000@Voip Your Life (216.143.130.64:31404) with Media Server (12.219.100.176:9222)
    14:11:02.781 StratInOut::eek:nConnected [CM104005] Call(403): Setup completed for call from Ext.1001 to Ln:10000@Voip Your Life
    14:11:02.781 CallLegImpl::eek:nConnected [CM103001] Call(403): Created audio channel for Ext.1001 (192.168.0.69:5006) with Media Server (12.219.100.176:9220)
    14:10:37.359 CallConf::eek:nProvisional [CM103003] Call(403): Ln:10000@Voip Your Life is ringing
    14:10:36.484 CallConf::eek:nIncoming [CM103002] Call(403): Incoming call from 1001 (Ext.1001) to sip:6413092821@192.168.0.61
    14:10:26.953 StratLink::eek:nHangUp [CM104001] Call(402): Ext.1001 hung up call; cause: BYE; from IP:12.219.100.176
    14:10:23.015 CallLegImpl::eek:nConnected [CM103001] Call(402): Created audio channel for Ln:10000@Voip Your Life (216.143.130.49:10588) with Media Server (12.219.100.176:9218)
    14:10:23.000 StratInOut::eek:nConnected [CM104005] Call(402): Setup completed for call from Ext.1001 to Ln:10000@Voip Your Life
    14:10:23.000 CallLegImpl::eek:nConnected [CM103001] Call(402): Created audio channel for Ext.1001 (192.168.0.69:5004) with Media Server (12.219.100.176:9216)
    14:09:51.250 CallConf::eek:nProvisional [CM103003] Call(402): Ln:10000@Voip Your Life is ringing
    14:09:50.343 CallConf::eek:nIncoming [CM103002] Call(402): Incoming call from 1001 (Ext.1001) to sip:5637733931@192.168.0.61
    14:09:38.375 CallConf::Rejected [CM103005] Call(401) is rejected: Destination is not answering
    14:09:38.375 StratInOut::eek:nCancel [CM104008] Call(401): Call from Ext.1001 to 1003 terminated; cause: 408 ; internal
    14:09:38.375 CallTarget::create [CM005001] Forward loop detected for destination 1003Forward history:{1003}
    14:09:20.562 CallConf::eek:nIncoming [CM103002] Call(401): Incoming call from 1001 (Ext.1001) to sip:1003@192.168.0.61
    14:09:10.515 StratInOut::eek:nHangUp [CM104007] Call(400): Call from Ext.1001 to 1006 has been terminated by Ext.1001; cause: CANCEL; from IP:192.168.0.69
    14:08:58.421 CallConf::eek:nIncoming [CM103002] Call(400): Incoming call from 1001 (Ext.1001) to sip:1006@192.168.0.61
    14:08:50.281 StratInOut::eek:nHangUp [CM104007] Call(399): Call from Ext.1001 to 1006 has been terminated by Ext.1001; cause: CANCEL; from IP:192.168.0.69
  9. SY
    3CX Support
    Jan 26, 2007
    1,825
    ...PBX<-OK_FROM_OTHER_PARTY
  10. tazz
    tazz New Member
    Sep 12, 2007
    124
    What does this last post mean?
    :13.531 CallConf::Rejected [CM103005] Call(9) is rejected: Destination is not answering
    15:31:13.531 StratInOut::eek:nCancel [CM104008] Call(9): Call from Ext.1005 to 1006 terminated; cause: 408 ; internal
    15:30:58.046 CallConf::eek:nIncoming [CM103002] Call(9): Incoming call from 1005 (Ext.1005) to sip:1006@mattlorenz.com
  11. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    In my understanding it shows exactly what SY said...
    External phone isnt sending the signal to PBX that he picked up the call or somehow that signal isnt getting to the PBX, for that same reason the phone keeps ringing even after the other party pick up...
    CHeers
  12. tazz
    tazz New Member
    Sep 12, 2007
    124
    That is correct. Those are the symptoms. You sound like you have faught with this in the past? Is this a router challange? Phone or 3cx issue?
  13. tazz
    tazz New Member
    Sep 12, 2007
    124
    I really want to thank everyone for their imput, although I'm still having issues. Just as miraportuga made mention that appears to be the problem
  14. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    I dont know know what it might be, shouldnt be a problem from the other party(the one that picks up the call) since internal traffic generaly goes thourgh firewall withouth any questions. Maybe something to do with DMZ? never worked with DMZ so no idea.... also it can be a phone problem or not... you never mentioned what phones you're using. I know i have here some "cheap" ip phones that tried and tried and simpy they wont work well with stun. without it. it works great, with it... forget it, line registers, you can place calls, you have no audio thoug...
    Cheers
  15. tazz
    tazz New Member
    Sep 12, 2007
    124
    Cheap maybe the word. Grandstream, I'm using an ATA 386 as well BT 101 and GXP 2000. Could the Grandstream product need something turned on or off aside from stun? I've used these phones in other applications & on other phone servers and have always done well, although at this point with my frustrations I'm willing to accept anything. With stun applied and DMZ at both ends. What is next?
  16. tazz
    tazz New Member
    Sep 12, 2007
    124
    OK for some reason My Primary number is now working, although the remote phone at hand I am pointing a second number for inbound only to that phone. That number rings but as before no audio & even after the call is disconnected the Remote Phone continues to ring. In all of this I'am still DMZ at both ends..
