Polycom 335
Discussion in 'Windows' started by jdflyer, Mar 2, 2015.
  1. jdflyer
    Jan 8, 2015
    5
    Hi guys,
    I'm still playing around with 3cx and trying to learn it. I have a semifunctional system right now and am moving over to trying to configure Polycom handsets.
    I have the Polycom configured and registered. When I try to make an outbound call the extension status shows it dialing, but it never makes it to the trunk. When calling extension to extension it will ring the outbound extenstion, but there is no audio when answered. Wondering if anyone has any thoughts or what I might have omited.
    thanks in advanced
    01-Mar-2015 18:36:34.706 L:47.1[Extn]: Terminating targets, reason:
    01-Mar-2015 18:36:34.706 Leg L:47.1[Extn] is terminated: Cause: BYE from PBX
    01-Mar-2015 18:36:34.706 L:47.1[Extn] Sending: OnSendResp Send 480/INVITE from 0.0.0.0:0 tid=5386cc9eCF8D707E Call-ID=3325ff7e-7158111e-4be91dfe@192.168.101.112:
    SIP/2.0 480 Temporarily Unavailable
    Via: SIP/2.0/UDP 192.168.101.112;branch=z9hG4bK5386cc9eCF8D707E
    To: <sip:6025551212@192.168.101.20;user=phone>;tag=cb1d297f
    From: "7002"<sip:7002@192.168.101.20:5061>;tag=1B05DE7E-5E5DEE1E
    Call-ID: 3325ff7e-7158111e-4be91dfe@192.168.101.112
    CSeq: 2 INVITE
    Warning: 499 3CX_Server "No answer"
    Content-Length: 0
    01-Mar-2015 18:36:34.656 [CM503020]: Call(C:47): Normal call termination. Call originator: Extn:7002. Reason: No answer
    01-Mar-2015 18:36:34.656 [CM503016]: Call(C:47): Attempt to reach <sip:6025551212@192.168.101.20:5060> from Extn:7002 has failed. Reason: No Answer
    01-Mar-2015 18:36:34.656 L:47.1[Extn] failed to reach DirSip:DirectSIP>><sip:6025551212@192.168.101.20;user=phone>, reason No Answer
    01-Mar-2015 18:36:34.655 Call to T:DirSip:DirectSIP>><sip:6025551212@192.168.101.20;user=phone>@[Dev:sip:6025551212@192.168.101.20;user=phone] from L:47.1[Extn] failed, cause: Cause: 408 Request Timeout/INVITE from local
    01-Mar-2015 18:36:02.561 [CM503025]: Call(C:47): Calling T:DirSip:DirectSIP>><sip:6025551212@192.168.101.20;user=phone>@[Dev:sip:6025551212@192.168.101.20;user=phone] for L:47.1[Extn]
    01-Mar-2015 18:36:02.521 [Flow] Call(C:47): making call from L:47.1[Extn] to T:DirSip:DirectSIP>><sip:6025551212@192.168.101.20;user=phone>@[Dev:sip:6025551212@192.168.101.20;user=phone]
    01-Mar-2015 18:36:02.521 [CM503027]: Call(C:47): From: Extn:7002 ("7002" <sip:7002@192.168.101.20:5061>) to T:DirSip:DirectSIP>><sip:6025551212@192.168.101.20;user=phone>@[Dev:sip:6025551212@192.168.101.20;user=phone]
    01-Mar-2015 18:36:02.521 [CM503004]: Call(C:47): Route 1: from L:47.1[Extn] to T:DirSip:DirectSIP>><sip:6025551212@192.168.101.20;user=phone>@[Dev:sip:6025551212@192.168.101.20;user=phone]
    01-Mar-2015 18:36:02.521 [Flow] Call(C:47): has built target endpoint: DirSip:DirectSIP>><sip:6025551212@192.168.101.20;user=phone> for call from L:47.1[Extn]
    01-Mar-2015 18:36:02.515 [CM503010]: Call(C:47): Making route(s) from Extn:7002 to <sip:6025551212@192.168.101.20:5060>
    01-Mar-2015 18:36:02.515 Remote SDP is set for leg L:47.1[Extn]
    01-Mar-2015 18:36:02.515 [CM505001]: Endpoint Extn:7002: Device info: Device Identified: [Man: Polycom;Mod: SoundPoint IP Series;Rev: General] Capabilities:[reinvite, replaces, unable-no-sdp, no-recvonly] UserAgent: [PolycomSoundPointIP-SPIP_335-UA/4.0.7.2514] PBX contact: [sip:7002@192.168.101.20:5061]
    01-Mar-2015 18:36:02.514 [CM500002]: Call(C:47): Info on incoming INVITE from Extn:7002:
    Invite-IN Recv Req INVITE from 192.168.101.112:5060 tid=5386cc9eCF8D707E Call-ID=3325ff7e-7158111e-4be91dfe@192.168.101.112:
    INVITE sip:6025551212@192.168.101.20:5061;user=phone SIP/2.0
    Max-Forwards: 70
    Contact: <sip:7002@192.168.101.112>
    CSeq: 2 INVITE
    Accept-Language: en
    Allow: INVITE, ACK, BYE, CANCEL, OPTIONS, INFO, MESSAGE, SUBSCRIBE, NOTIFY, PRACK, UPDATE, REFER
    Content-Type: application/sdp
    Proxy-Authorization: Digest username="1000",realm="3CXPhoneSystem",nonce="414d535c0b044f8246:f88c7a1c7183583953e60bba32450ccf",uri="sip:6025551212@192.168.101.20:5061;user=phone",response="aff010570e385356028d3472e7194486",algorithm=MD5
    Supported: 100rel, replaces
    User-Agent: PolycomSoundPointIP-SPIP_335-UA/4.0.7.2514
    Allow-Events: conference, talk, hold
    Content-Length: 376
    v=0
    o=- 1425260161 1425260161 IN IP4 192.168.101.112
    s=Polycom IP Phone
    c=IN IP4 192.168.101.112
    t=0 0
    a=sendrecv
    m=audio 2224 RTP/AVP 110 117 0 8 9 18 101
    a=rtpmap:110 iLBC/8000
    a=fmtp:110 mode=30
    a=rtpmap:117 L16/16000
    a=rtpmap:0 PCMU/8000
    a=rtpmap:8 PCMA/8000
    a=rtpmap:9 G722/8000
    a=rtpmap:18 G729/8000
    a=fmtp:18 annexb=no
    a=rtpmap:101 telephone-event/8000
    01-Mar-2015 18:36:02.514 [CM503001]: Call(C:47): Incoming call from Extn:7002 to <sip:6025551212@192.168.101.20:5060>
  2. captain415
    Mar 4, 2012
    9
    Are you using port 5061 on ext 7002 for a reason? Try setting everything back to 5060 first and see if that'll work.
