Polycom 501 intercom
Discussion in '3CX Phone System - General' started by i3, Aug 22, 2013.
  1. i3
    i3
    Jun 6, 2012
    31
    Anyone get a Polycom 501 phone working with the intercom feature in 3cx?
  2. i3
    i3
    Jun 6, 2012
    31
    Figured it out finally. You will need to add the below line in the sip.cfg file.
    <alertInfo voIpProt.SIP.alertInfo.2.value="Ring Answer" voIpProt.SIP.alertInfo.2.class="4"/>
    I can go in more detail if anyone needs it. PM me.
