polycom 501 SEND button
Discussion in '3CX Phone System - General' started by abelaguilar, Nov 27, 2007.
  1. abelaguilar
    Nov 4, 2007
    94
    Does anyone know of a way to setup my polycom 501 so that I don't have to press the "SEND" button when I want to make a call?
    Right now I have to enter the numbers and press the SEND button and its an annoying extra step.
    Thanks!!!
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    1. Login your Polycom via web admin
    2. Click SIP
    3. Click Local Setting
    You will found the Digitmap over here.
    eg.
    If your extension with 3 digits, start with 8 and "9" outbound rule to PSTN
    [8]xx|[9]xxxx.T
    xxxx, xx - min. digits
    [8]xx - If press 801, it will issue a SIP call to extension without press dial.
    [9]xxxx.T - If press 912345678, it will issue a SIP call to PSTN number 12345678 without press dial.
    It works for our IP330. It should be works at IP501 as well. Since them almost the same setup.
  3. abelaguilar
    Nov 4, 2007
    94
    thanks i'll try that
