Polycom 501
Discussion in '3CX Phone System - General' started by kmoser, Apr 17, 2013.
  1. kmoser
    Apr 14, 2013
    At one point I had my Polycom 501 registered, but no codec listed in the Provisioning Tab. Some one suggested I reset the phone, which I did but now it is not registering. I'm getting "Credentials don't match, check that authorization-ID and password match the ones in extension settings". I have reset them twice with no results.
    Does anyone have a working configuration file for the Polycom 501 SIP?
    The display is reading the 3.1.8 firmware.
    Any suggestions?
    Also can someone give me an example of an outbound rule: my trunk uses E. 164 format: (country code)(phone number)?
