Polycom 550 and 650
darryla
I'm considering getting a pair of either Polycom 550 or 650 phones. What caught my fancy was their "HD Voice" thing.
Does that really do anything?
Can it work with 3CX?
Yes, I have looked at the information.
The HD setting will just use a specific Codec phone to phone. So they should work fine with 3CX. for external calls they should just fall back to a default codec like G7.11 or GSM.
Not personaly sure if they are worth it?
Cheers
Neil
Polycom 550 HD will work with 3CX.
We hare having a transfer call issue.
we believe that is cause by firmware.
Can you describe the issue? Have you had good luck with any other phones?
Hi zmalimar,
Please post the console log here for the call transfer issue.
Getting Started - Admin
ICT BE Peleman
Get 3CX - Absolutely Free!
3CX
