Polycom 650 time format provisioning template
Discussion in 'Windows' started by mixig, Jul 5, 2012.
  1. mixig
    mixig Active Member
    Dec 13, 2011
    519
    11
    i am trying to find the option in provisioning template for change time format from 12h to 24h but i can t see that anywhere , can anybody help?
    thanks
  2. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    Access the phones web GUI go to general tab the time and you can change time format there.
  3. mixig
    mixig Active Member
    Dec 13, 2011
    519
    11
    Ok, i thought that I can do that via template without doing manually...
  4. jpillow
    Jun 20, 2011
    1,342
    Not sure if you could do it for in the the provisioning or. It but it can easily be done manually
