Polycom HD Internal, G729 External
Discussion in '3CX Phone System - General' started by depthless, Oct 3, 2011.
  1. depthless
    Oct 3, 2011
    8
    Is it possible to set G722 as the codec for internal calls and G729A/B as the codec for calls to my VOIP provider?
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Yes, It is possible
  3. depthless
    Oct 3, 2011
    8
    Hmm, maybe I'm doing something wrong then.
    Under Extensions > Phone Provisioning > Codec Priority > Preferred Codec = G722, Second Preferred Codec = G729A/B
    Under VOIP Providers > Bandwidth.com > Advanced > Codec Priorities > Assigned Codecs = G729, G.711 U-law
    Yet both internal and external calls have the HD logo on the Polycom phone. Any ideas?
  4. SY
    3CX Support
    Jan 26, 2007
    1,825
    You are doing everything correct.
    What is the issue?
  5. depthless
    Oct 3, 2011
    8
    External calls are using Polycom's "HD Voice" when they shouldn't be. It's a waste of bandwidth.
    I'm looking at the Server activity log, but it doesn't state what codec was used for a call.
  6. SY
    3CX Support
    Jan 26, 2007
    1,825
    Here is the explanation how it works.
    http://www.3cx.com/blog/docs/media-server/
    to be honest, I don't understand why do you think that
  7. depthless
    Oct 3, 2011
    8
    Doesn't G722 use significantly more bandwidth than G729?
  8. SY
    3CX Support
    Jan 26, 2007
    1,825
    Please read my post and the article (link).
    If you prefer the instant answer then it is:
    You are using G729 to talk to your VoIP provider even in case if your phone shows "HD Voice" on the screen.
    P.S. If you don't believe it. You can verify it using wireshark or any other tool you prefer. Log does not show codec just because it is not necessary.
    Regards
