Polycom IP320 and Multicast Paging
Discussion in '3CX Phone System - General' started by pcjohn, Dec 24, 2009.
  1. pcjohn
    Sep 15, 2009
    6
    Has anyone bee able to get the multicast paging/intercom to work on the Polycom phones ?
    I had it working briefly on V8 when you could send out over a range of IPs but the newer
    version only broadcasts on one IP. I've had no luck getting any IP to work.
    I know it's not a switch or router issue because I have 4 Aastras that work perfectly
    no matter what address or port I use (in the 224. range of course).
    Thanks,
    JD
