Polycom IP331 Change Callers button
Discussion in '3CX Phone System - General' started by tsukraw, Feb 4, 2016.
  1. tsukraw
    tsukraw New Member
    Mar 9, 2012
    190
    7
    Hey,
    First off i am no polycom expert, coundnt find a way to do this so figured i would ask.
    On a IP331 phone there is a Callers button on the home screen. Is that button able to be changed to something else like a sped dial?
    Thanks!
