Polycom IP335 Hard Button
Discussion in '3CX Phone System - General' started by latitude, Feb 21, 2013.
  1. latitude
    Mar 22, 2010
    11
    Where in the provisioning files can I find the 4 buttons under the screen so I can modify them. I didn't have an issue finding the BLF's and hard coding those, but need to be able to put a SP button on the IP335's.
  2. GManNAtl
    Sep 13, 2012
    58
    It is just done in 3CX console under the phone provisioning. You don't need to manually edit the template. The drop down allows you to make it either BLF or SP among a few other choices.
    The only real question is that the 335 is only a 2 line phone. So you can put the extension and one other key so I don't see how you are going to get a BLF and a shared park?
