polycom ip430
Discussion in '3CX Phone System - General' started by hkgonra, Apr 3, 2018.
  1. hkgonra
    Apr 3, 2018
    Is there a reason why the ip430 is not supported ?
    I have a mix of 330's and 430's and was planning to upgrade my aging trixbox to 3cx.
    Is there a work around ?
  2. cobaltit
    cobaltit Well-Known Member
    Mar 22, 2012
    1,752
    274
    The work around is called manual provisioning
    hkgonra likes this.
  3. hkgonra
    Apr 3, 2018
    Do you happen to have any instructions for that ?
  4. phonemaster
    Nov 9, 2017
    91
    35
    hkgonra likes this.
  5. eddv123
    eddv123 Well-Known Member
    Aug 15, 2017
    1,577
    209
    hkgonra likes this.
  6. hkgonra
    Apr 3, 2018
    I tried adding them as a 330 and a 501, the 450 uses a newer firmware than the 430 can handle so I didn't think that would work but will try.
  7. eddv123
    Aug 15, 2017
    1,577
    209
    Polycom's are normally very sensitive to firmware with 3CX (if being provisioned).
    If this doesn't work then simply setup an extension on 3CX, login to the phone and register manually using the Username/password from the extension on 3CX and Registrar address (as 3CX).
    This will give you a quick, easy albeit manual fix.
    hkgonra likes this.
