Polycom Message Waiting Beep
Discussion in '3CX Phone System - General' started by nxtgen, Jul 31, 2013.
  1. nxtgen
    Jun 3, 2008
    Anyone know how to turn this off?? I found the configuration options on Polycom's webstie, but the 3CX template appears to have it's own "syntax" that 3CX then turns into a Polycom config file. I'm hoping someone has done this before and already has the 3CX lingo in the configuration file down for this :-/
    Thanks!
  2. fioreit
    Apr 6, 2012
    23
    Add this to your provisioning template.
    I stuck it right before the BLF config section. Works great for me using IP 650's.
    Or you can manually add it to one of your "polycom-fw40x-MACADDRESS.cfg" files.
    <se>
    <se.pat>
    <se.pat.misc>
    <se.pat.misc.messageWaiting>
    <se.pat.misc.messageWaiting.inst se.pat.misc.messageWaiting.inst.1.value="0" se.pat.misc.messageWaiting.inst.2.value="0" se.pat.misc.messageWaiting.inst.3.value="0" />
    </se.pat.misc.messageWaiting>
    </se.pat.misc>
    </se.pat>
    </se>
