Polycom Multi DID to Line Buttons
Discussion in '3CX Phone System - General' started by readingfire, Aug 22, 2012.
  1. readingfire
    Aug 4, 2012
    I am relatively new to 3CX. I have 2 phones configured manually with the web gui. These are extensions 10 & 11. I have set up all call which rings all phones correctly. However, I have 2 incoming sip lines with associated DID's.
    On DID 1 I want Line 1 to ring.
    On DID 2 I want Line 2 to ring.
    I would also like to use the Line Busy LED's on the phones. For example.. Should Line 1 (DID 1) be in use on ext 10 I would like the Line 1 LED to show RED.
    Has anyone achieved the above or can offer any help?
    Regards
    Martin
  2. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    When you say line one and line two are you referring to the extensions? do you have to physical lines coming in the building and want to distinguish between the two. Or a certain phone you consider line one, and another line two? Please be a little bit more specific on what exactly your trying to do. That may help you get an answer.
  3. readingfire
    Aug 4, 2012
    Ok.. I have 2 SIP Lines registered with providers. Each has a different number. On the phone (Polycom 550) I have Softkeys that I have called Line 1 and Line 2.
    I would like the first SIP account to ring the softkey known as "Line 1" and the second SIP account o ring the softkey known as "Line 2"
    The phone itself is known as extension 10.
    Regards
    Martin
  4. jpillow
    Jun 20, 2011
    1,342
    You can assign each phone to a BLF key and make all calls going to one sip trunk assigned to a particular phone, though I dont believe you can assign the sip trunks to a BLF key.
  5. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,083
    61
    Assuming the 550 is a mutli-account capable phone, you could actually assign two extensions to each phone and then direct the associated DID#1 to ring account/extension 10 and then have DID#2 ring extension 11; then its just a matter of which button you have assigned to reflect each account.
