Polycom - Multiple Incoming Calls Per Phone
Discussion in '3CX Phone System - General' started by SnAzBaZ, May 5, 2011.
  1. SnAzBaZ
    Nov 9, 2007
    28
    I have recently upgraded our Polycom Soundpoint IP 320 & 330 phones to Polycom SIP 3.3.1.0769 and BootROM 4.2.0.0310. This update required new configuration files which we have created. However now each phone can only receive one incoming call, previously they could handle two calls.
    The IP330 and IP320 have two Line keys. In one of our global configuration files we have:
    <reg reg.1.lineKeys="2" reg.1.callsPerLineKey="2" reg.1.server.1.expires="300" reg.1.ringType="13"></reg>
    But it does not allow two calls. We have also tried setting the callsPerLineKey to 1.
    Note we don't want to register two different extensions, I would just like the phone to ring with the second call if Line 1 is busy. That way the person on the phone gets notification that another call is coming in and can decide if they want to answer it or let it go to VM etc.
    Any suggestions as to how we get two calls again?
    Thank you.
  2. FGCUHank
    FGCUHank New Member
    Feb 27, 2010
    101
    Did you check the box in the extension setup to allow multiple calls?
  3. SnAzBaZ
    Nov 9, 2007
    28
    No, and I was not aware that there was one, but I have now found it. Thank you. Hopefully that will solve the issue, I will see.
  4. willow
    willow Member
    Mar 1, 2011
    471
    that should do it.
  5. north3
    Jul 3, 2009
    9
    Can someone point me into the directio of where I can configure the extension setup to allow multiple calls. I have looked at the extension settings and I am not able to locate it. I have a Yealink phone.
    Thanks,
    Jack
  6. leejor
    10,373
    230
    #6 leejor, Mar 13, 2013
  7. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    Extensions---->Forwarding Rules---->I want to be able to accept more than one call at a time.
    Also in settings--->advance---->custom parameters--->ALLOWBUSYOPTFORGROUP--->value should be set for 1
