Polycom MWI
Discussion in '3CX Phone System - General' started by SnAzBaZ, Dec 18, 2008.
  1. SnAzBaZ
    Nov 9, 2007
    28
    Just purchased 3CX and want to get the MWI working for my Polycom phones. At the moment it is not lighting up when a message has been left. This worked when I was using a hosted VOIP provider, so the Polycom configuration should be OK. Do I need to enable something in 3CX ?
    3CX Version: 7.0.3775.0
    Andrew
  2. SnAzBaZ
    Nov 9, 2007
    28
    I restarted Windows for some updates, and it's working now, so who knows!
    Andrew
