Polycom provisioning disable missed calls
Discussion in '3CX Phone System - General' started by netswork, Oct 17, 2012.
  1. netswork
    netswork Active Member
    Mar 11, 2011
    577
    Had a customer wanting to turn off missed calls. I was able to get it working with the following added to the provisioning template. This is on firmware 4.0.2b using the provisioning file 4.0.x from version 11.
    Code:
    <feature
        feature.directedCallPickup.enabled="1"
        feature.urlDialing.enabled="0"
        feature.callListMissed.enabled="0"
    <feature>
     <callListMissed
    </feature>
