Polycom SoundStation 6000 drops calls after 30 mins.
Discussion in '3CX Phone System - General' started by entertech, Apr 18, 2016.
  1. entertech
    Jan 14, 2016
    We have a Polycom for our conference room, when a call hits 30 mins on the dot the external line disconnects but the polycom still shows the active call.
    I have made calls from other IP phones using the same trunk just fine.
    Any ideas?
  2. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,386
    88
    In the Server Activity Log, make a call, wait until in it hangs, the check the logs, at least to see which side is sending the BYE message, then maybe you can work towards the correct direction.
  3. entertech
    Jan 14, 2016
    Issue was related to outdated firmware.
    Thanks for the follow up.
