Polycom Soundstation IP 5000 Authentication
Discussion in '3CX Phone System - General' started by Fastflow, Feb 20, 2014.
  1. Fastflow
    Feb 20, 2014
    I have a Polycom Soundstation IP 5000 which I am trying to setup on 3CX v12.
    Here are the details of the IP 5000
    Phone Information
    Phone Model SoundStation IP 5000
    Part Number 3111-30900-001 Rev:G
    MAC Address 00:04:F2:F3:4A:FD
    IP Address 192.168.11.52
    UC Software Version 4.0.1.13681
    BootROM Software Version 5.0.1.10553
    I have setup Boot 66 on our server pointing to the provisioning folder ok.
    I have setup the SIP configuration on the phone, but I cannot get the phone to authenticate.
    The username and password on the phone and in 3CX are the same.
    Here is the log from 3CX
    20-Feb-2014 14:52:16.423 [CM302001]: Authorization system can not identify source of: UnkSrc Recv Req SUBSCRIBE from 192.168.11.52:5060 tid=4b3b8900940E02AB Call-ID=99470de-2d8fac59-7114ffdc@192.168.11.52:
    SUBSCRIBE sip:461@192.168.11.235:5060 SIP/2.0
    Via: SIP/2.0/UDP 192.168.11.52:5060;branch=z9hG4bK4b3b8900940E02AB
    Max-Forwards: 70
    Contact: <sip:Golborne@192.168.11.52:5060>
    To: <sip:461@192.168.11.235>
    From: "Boardroom"<sip:Golborne@192.168.11.235>;tag=13544269-2062FF6C
    Call-ID: 99470de-2d8fac59-7114ffdc@192.168.11.52
    CSeq: 1 SUBSCRIBE
    Expires: 120
    Accept: application/simple-message-summary
    Accept-Language: en
    Allow: INVITE, ACK, BYE, CANCEL, OPTIONS, INFO, MESSAGE, SUBSCRIBE, NOTIFY, PRACK, UPDATE, REFER
    User-Agent: PolycomSoundStationIP-SSIP_5000-UA/4.0.1.13681
    Event: message-summary
    Content-Length: 0
    20-Feb-2014 14:52:09.038 [CM102001]: Authentication failed for AuthFail Recv Req REGISTER from 192.168.11.52:5060 tid=6bbe30269F386661 Call-ID=6f9da825-a9acf8c8-c211b933@192.168.11.52:
    REGISTER sip:192.168.11.235:5060 SIP/2.0
    Via: SIP/2.0/UDP 192.168.11.52:5060;branch=z9hG4bK6bbe30269F386661
    Max-Forwards: 70
    Contact: <sip:Golborne@192.168.11.52:5060>;methods="INVITE, ACK, BYE, CANCEL, OPTIONS, INFO, MESSAGE, SUBSCRIBE, NOTIFY, PRACK, UPDATE, REFER"
    To: <sip:Golborne@192.168.11.235>
    From: "Boardroom"<sip:Golborne@192.168.11.235>;tag=7A8627DB-14229A8E
    Call-ID: 6f9da825-a9acf8c8-c211b933@192.168.11.52
    CSeq: 2 REGISTER
    Expires: 120
    Accept-Language: en
    Proxy-Authorization: Digest username="461",realm="3CXPhoneSystem",nonce="414d535c0916a79868:8a79c6b21534154606da6fb9080e518d",uri="sip:192.168.11.235:5060",response="b6f45f828bfa16f546982dbbe46bf202",algorithm=MD5
    Content-Length: 0
    Any ideas?
    Stephen
  2. sigma1
    sigma1 Active Member
    Nov 20, 2009
    542
    Stephen:
    if you use option66 you don't need to change anything in the Polycom. If you configured the PolyCom via the web interface please post a screenshot, you may have forgotten something.
    Take a look at http://www.3cx.com/sip-phones/polycom-soundstation-5000-6000-7000/
  3. Fastflow
    Feb 20, 2014
    HI is this enough or do you need the full details.
    [​IMG]
  4. sigma1
    Nov 20, 2009
    542
    Sorry it's way too small, please crop only the settings part
  5. Fastflow
    Feb 20, 2014
  6. leejor
    10,587
    253
    Where you have Golborne, in "Address", should that not be the extension number?
  7. sigma1
    Nov 20, 2009
    542
    Address = SIP Auth = Extension - fix that and you should be ok
