Poor Inbound call quality - newbie
Discussion in '3CX Phone System - General' started by dbergsma, Oct 27, 2008.
  1. dbergsma
    Oct 27, 2008
    39
    Hi Folks,
    I have download 3cx free version - 6.1.0 on w2008, linksys spa942, and grandstream 4104 (v1.0.08) for FXO to PSTN.
    I'll do the upgrade once I have proof of concept working.
    Outbound calling works no problem.
    Calls between extensions seems to work fine.
    On PSTN In bound calling - my wife says I sound like Darth Vader with the sound of a light saber whirring in the background.
    On the IP phone - the PSTN in bound caller sounds fine, however, the PSTN caller hears a remake of star wars.
    Any ideas?
    Thanks in advance
    Dean.
  2. dbergsma
    Oct 27, 2008
    39
    correction -- grandstream firmware is
    Software Version: Program-- 1.0.1.8 Loader-- 1.1.3.3 Boot-- 1.1.3.2
  3. galal202
    galal202 New Member
    Jun 23, 2008
    235
    Hello dbergsma and welcome
    I have 4104 and it works fine with 3cx
    this my settings
    restore to factory set then reconfig it again
  4. mobilesoundz
    Oct 24, 2008
    19
    I had a similar issue with a linksys 3102 i had to increase the gain settings to +15 which made it crystal clear and even over the wirelss lan :)
  5. galal202
    galal202 New Member
    Jun 23, 2008
    235
    What about echo after +15gain?
  6. mobilesoundz
    Oct 24, 2008
    19
    have not experienced any echo, no delay just a really nice quality voice... Try it and see what happens
  7. wzaatar
    Aug 1, 2007
    90
    What codecs are you using on your IP Phone and your Grandstream PSTN gateway?
  8. dbergsma
    Oct 27, 2008
    39
    711u
    however, turned on pbx delivers audio. all is good.
  9. wzaatar
    Aug 1, 2007
    90
    I can think of two reasons: Either the RTP packet size not correct, or it's a simple firewall problem...
    Cheers,
    W.
  10. dbergsma
    Oct 27, 2008
    39
    changed out grandstream with patton, no problems, I'm happy with 3cx now.
    can't say I would recomend grandstream.
    dean.
