Poor Quality on SIP Trunks
Discussion in '3CX Phone System - General' started by Wendelspanswick, Mar 13, 2017.
  1. Wendelspanswick
    Jan 11, 2016
    83
    Hi All
    We have a 3CX V14 install with Yealink T23g handsets that uses a combination of ISDN30 trunks via a Patton gateway and SIP trunks via a TalkTalk ADSL line. The customer is happy with the ISDN30 but every time we put them on the SIP trunks we get complaints of poor speech quality.
    The ADSL supports 7 MBs down and 0.64 MBs up so in theory it should support 10 simultaneous calls on the G.711 a CODEC although in practice we have never tried running more than 4 simultaneous calls.
    We have monitored the router and it never approaches maximum bandwidth, the connection tests OK with no dropped packets, we are running out of ideas now, any suggestions.
  2. Wendelspanswick
    Jan 11, 2016
    83
    Think I may have answered my own question, SIP trunks were set to G.711 a and G.729 CODECs but Yealink handsets don't have the G.711 a in the config so I guess the calls were defaulting to G.729. Now I've changed the SIP to G.722 which the Yealinks do have in their config and I will run some tests.
  3. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
    Pcma and pcmu in yealink is g711a/u... with less than 1mb up personally I wouldn't attempt external voip (although that was my home setup for many years and it worked fine once I had qos setup.)
  4. Wendelspanswick
    Jan 11, 2016
    83
    Just to complicate things TalkTalk don't support G.722, only G.711a or u so it looks like we will have to modify the provisioning template for the Yealinks to add G.711.
  5. Wendelspanswick
    Jan 11, 2016
    83
    That's interesting, I wondered why there was no G.711 on the Yealink, doesn't solve my problem though.:(
