Port 5000 and 5001 security concern
Discussion in '3CX Phone System - General' started by sbowers, Nov 17, 2017.
  1. sbowers
    Feb 23, 2015
    12
    We are concerned with the ports that 3CX uses for the web portal. I have clients that want to use the BLF information remotely on their smartphones and their laptops. We have been locking down port 5000 and 5001 from access from the web outside of their environment. The reason for this is that we feel that this is a huge security hole to have the management console port open to the world. Does anyone have any suggestions or plans to change BLF mapping by using different ports so that this works outside of the LAN without jeopardizing the management console? The same for clients. Thanks.
  2. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
    We can see that concern exists for some time:
    https://www.3cx.com/community/threa...the-admin-dashboard-on-different-ports.47890/
    #2 Sopock, Nov 17, 2017
  3. cobaltit
    cobaltit Well-Known Member
    Mar 22, 2012
    1,198
    188
    v15 uses nginx now so you can edit the config to accomplish what you want.
