Port 5060 failing in firewall check
Discussion in '3CX Phone System - General' started by 805tech, Sep 18, 2013.
  1. 805tech
    Aug 30, 2013
    39
    For some reason port 5060 fails on firewall check. When I use a outside source to check it I get that its opened. Any one else ever had this problem?
    10,362
    227
    What type of router/firewall are you using? Some play better with 3CX than others.
    If you list the model, someone familiar with it may have some pointers.
  3. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    if you have setup port forwarding correctly and SIP ALG is turned off.
    my betting would be the router may have built in VoIP Services, but without knowing more details we will not know for sure.
  4. 805tech
    Aug 30, 2013
    39
    SIP ALG was on I turned it off works fine thank you!!!
  5. borderhopper
    Dec 21, 2015
    I hope this thread is still live - I'm a newbie and have a similar problem. All ports shown as success on firewall check except 5060 failing. Draytek 2830 - SIP ALG confirmed off. Ports forwarded ok - however checks from outside show all ports closed Any suggestions welcome.
  6. leejor
    10,362
    227
    Did you come across this...
    http://www.3cx.com/blog/docs/draytek-firewall-voip/
    and have a read through? Not exactly the same model, but...
    Also this... http://support.it-communicationsltd.co.uk/hc/en-us/articles/203206482-How-to-Setup-Draytek-Router-with-3CX-Setup
  7. borderhopper
    Dec 21, 2015
    Thanks very much - I hadn't seen either of those. Implemented both and all ports now successful on Firewall Checker. Still problems from the outside but should get to the bottom of that.
