PORT 5062
Discussion in '3CX Phone System - General' started by rodneyeid, Aug 19, 2007.
  1. rodneyeid
    Aug 8, 2007
    18
    i am changing my port for 3cx from 5060 to 5062. when i do this change my softphones do not register anymore!!!
    any help???
  2. Anonymous
    Anonymous Guest
    change the ports to 5062 aswell on the softphones.
  3. rodneyeid
    Aug 8, 2007
    18
    i did that already :lol:
    but forgot to mention it
  4. sittsh
    May 2, 2007
    19
    I have found that some soft phones use this port
    If i recall theres a soft phone out there that uses two port numbers above the port you enter , so if you enter 5060 it will also use 5062. Maybe it was for RTP or something like that. Sorry but i just can't remember what it used it for.
  5. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Your soft phone at local LAN or NAT over Internet?
    Have you enable the firewall at 3CX BOX?
  6. rodneyeid
    Aug 8, 2007
    18
    i am using it over NAT! and nor firewall on 3cx server.
  7. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    Just to recap first - you changed the port in 3CX "General Settings" tab to 5062 and updated the configuration of the softphone to the same, and you said you are connecting over NAT - so softphone is not on same LAN?
    If it is not I would suggest starting with a softphone on the same LAN, and make sure that it connects. This would help to establish if problem is with 3CX <-> Softphone setup, or elsewhere (port forwarding to 3CX from WAN, port blocking at softphone location, etc.).
    Gotta start somewhere and basics always best place to start.
  8. tjabaut
    tjabaut New Member
    Jul 24, 2007
    123
    You could also try to append the port on the end of the Proxy server field on you softphone. I.E. proxy.sip.com becomes proxy.sip.com:5062
