Port 80 Windows IIs
Discussion in '3CX Phone System - General' started by MB1, Dec 18, 2015.
  1. MB1
    MB1
    Nov 2, 2007
    39
    I have a II's web server using port 80. Can I configure 3CX to use port 8080 for http, if so how?
    Regards,
    MB
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,560
    301
    You should not have IIS running on the Phone Server for a website, except for use with 3cx.
    The Phone server at times needs a lot of resources which should not be shared with other applications, in this case, a website.
  3. complex1
    complex1 Active Member
    Jan 25, 2010
    814
    49
    No, this is not possible. You have to use Abyss as 3CX Webserver.
    Please read: http://www.3cx.com/docs/3cx-phone-v14-ports-system/
  4. MB1
    MB1
    Nov 2, 2007
    39
    Thanks everyone!
