Port firewall
Discussion in '3CX Phone System - General' started by liberars, Aug 23, 2007.
  1. liberars
    Aug 10, 2007
    32
    Which port must be opened on the firewall to connect a client remote?
    Regards
    Gianfranco
  2. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    Lots of good info here http://www.3cx.com/forums/viewtopic.php?t=1697&highlight=ports+sticky and specific ports
    These will allow all normal functions including external extensions.
    If your question instead is how to access the 3CX Admin page externally, the port is 5481.
  3. liberars
    Aug 10, 2007
    32
    Can you specifi which port are in listen on pbx?
    Regards
    Gianfranco
  4. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    I am not very sure exactly what type of info you are seeking since the quote I supplied did define TCP/UDP for any going through the WAN router
    On the local machine, if firewall equipped, I would just open those for all options. Shouldn't be a security risk if confined to the LAN only.
  5. liberars
    Aug 10, 2007
    32
    When the client is connect, I see opened also the 5483
    Opss
    page web open
    Now try
    Regards
    Gianfranco
  6. liberars
    Aug 10, 2007
    32
    All work many well,
    many thanks
    This PBX is excellent.
    Compliments to the developers.
    Regards
    Gianfranco
  7. liberars
    Aug 10, 2007
    32
    Prevent to call
    can prevent to an client to call.
    Regards
    Gianfranco
  8. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    I am happy you got it going. Yes, 3CX is a really good product, and they are doing really good improvements regularly. I have used Asterisk in different flavors, and Axon in the past, and 3CX has them all beaten without a doubt. When considered from a non-Linux (Windows mainly) user perspective.
