port forwarding? acts like voip call going but doesn't
Discussion in '3CX Phone System - General' started by Mori, Nov 9, 2007.
  1. Mori
    Mori New Member
    Mar 23, 2007
    223
    (Thnx Mirzab for this) :wink:
  2. Mori
    Mori New Member
    Mar 23, 2007
    223
    5060 (stanard sip port) TCP/UDP
    5061 (secondary sip port) TCP/UDP
    3478 (STUN Server) TCP/UDP
    9000 - 9003 (ports for external calls through VOIP Gateway) UDP
    10000-20000 (RTP ports) (Used if no stun available for audio)
    These ports must be opened and routed on to 3cx server.
    Your second choize is to set 3cx server to a virtual server in router firewall. (if your router suports it)
    Setting 3cx in DMZ is NOT recomended if your not absolutely shure what your doing.
    Good luck. :)
  3. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    Mori is correct except that 9000-9003 is needed for the calls, 2 ports/call. So 9000-9001, 9002-9003 would only let you have 2 calls. 9000-9009 would give you 5 simultaneous calls.
    Adjust as necessary.
  4. MajoR_Mess
    Dec 4, 2007
    11
    Why would all those ports need forwarding?
    5060 - 5061 OK understand that.
    3478 - Going to cause probs for any devices on network attempting to use external STUN servers.
    9000-9xxx No point NAT will open and close
    10000-20000 No point NAT will open and close
    Point is, forwarding large blocks of ports, some rfc assigned and some not, is still going to cause problems on your network with other applications.
