port forwarding
Discussion in '3CX Phone System - General' started by coreybrett, May 20, 2010.
  1. coreybrett
    Apr 12, 2010
    72
    I have 3CX installed and running behind a Linksys router that has a staic public address.
    I had port forwarding setup as directed in “http://www.3cx.com/blog/voip-howto/linksys-router-configuration/”, and everything worked.
    I'm using CallCentric for my SIP account, and I have STUN turned off.
    Today I turned off the port forwarding, and everything still works fine. I even unplugged the Linksys router for about 30 seconds and plugged it back in.
    How is it working without the port forwarding?
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    What is the issue?
  3. coreybrett
    Apr 12, 2010
    72
    i guess my lack of understanding it :)
    i'm just tring to understand how it all works, in-case it doesn't at some point
