Port SBC to OpenWRT / DD-WRT
Discussion in 'Ideas' started by Silly English Kniggit, Nov 11, 2017.
Port SBC to OpenWRT / DD-WRT 4.5 5 4votes
4.5/5, 4 votes
  1. Silly English Kniggit
    Sep 13, 2017
    220
    85
    That would allow the SBC to be installed on a good range of router hardware that either may be in use anyway, or is cheaper than a Raspberry Pi - such as https://www.gl-inet.com/ar150/ which are around GBP £25
    Currently I can download two open source phone systems (yes, the entire PBX) for that platform - but not the 3CX SBC.
    accentlogic likes this.
  2. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
    They think it's not powerful enough?
    pfSense | QNAP
  3. accentlogic
    accentlogic New Member
    Nov 14, 2013
    174
    72
    We use the NetGear R7000 in many small locations. BCM4709 dual core processor at 1GHz with 128GB of flash memory. That should handle quite a few extensions. Less powerful systems might only support a few, but some locations only need one extension behind the SBC.
    These cost more than a Raspberry Pi, but if we can eliminate an extra device it would be worth it.
