PorTech MV-370 dial out problem
Discussion in '3CX Phone System - General' started by AndreaL, May 28, 2008.
  1. AndreaL
    Apr 24, 2008
    12
    Hi everyone,
    I have a PorTech MV-370 configured as shown in Wiki category forum.
    All the incoming calls from GSM make my internal ring, but when i call from my internal (101) the GSM number, the outbound call is not fired.
    On 3cx log I see
    23:36:44.762 Call::Terminate [CM503008]: Call(3): Call is terminated
    23:36:44.746 Call::Terminate [CM503008]: Call(3): Call is terminated
    23:36:39.317 CallCtrl::eek:nLegConnected [CM503007]: Call(3): Device joined: sip:10001@192.168.0.22:5060
    23:36:39.302 CallCtrl::eek:nLegConnected [CM503007]: Call(3): Device joined: sip:101@192.168.0.30:5060
    23:36:38.943 Line::printEndpointInfo [CM505002]: Gateway:[PortTech GSM] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [CM5K (706220)] Transport: [sip:192.168.0.12:5060]
    23:36:38.475 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(3): Calling: PSTNline:10001@[Dev:sip:10001@192.168.0.22:5060]
    23:36:38.444 CallCtrl::eek:nIncomingCall [CM503001]: Call(3): Incoming call from Ext.101 to [sip:3493139351@192.168.0.12]
    then the call from 3cx is fired on PorTech but on the MV-370 device, under Mobile status I see
    Incoming IP: 101@10001
    Incoming IP Name: 101
    Outgoing IP:
    Incoming Mob:
    Outgoing Mob:
    Where is the mistake? I think in 3cx MV-370 gateway configuration but where?
    Thanks a lot,
    Andrea L.
  2. Anonymous
    Anonymous Guest
    is the gsm gateway showing as registered?
  3. AndreaL
    Apr 24, 2008
    12
    Yes, It is.
  4. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    Check outbound rules on PBX and GSM gateway.
  5. AndreaL
    Apr 24, 2008
    12
    Outbound roules are ok.
    For 3cx, i sow in the log the follows:
    Then internal 101 at 192.168.0.30:5060 "talk and exit" from 10001 at 192.168.0.22:5060
    On GSM gateway the outbound roules are (very simple) as explained in http://docs.google.com/View?docid=dqnz5cc_7t4436fhj at point 7:
    7. Click on the “Route” tab at the top right site of the page. Configure this page as follows:
    a. Set the “LAN To Mobile settings” field
    Add New
    a. Position:= 0
    b. URL:=*
    c. Call Num:= #
    d. Click the “Add” button at the bottom of the page.
    The strange thing is that on GSM gateway, during the outbound call, under Mobile status I see
    Outgoing IP:
    Incoming Mob:
    Outgoing Mob:
    The incoming IP would be 192.168.0.30 (the 101 internal or the 192.168.0.12 that is the 3cx pbx), not 101@10001?!
    And the Outgoing Mob: that remain blank, vould be the number 3493139351 of the call log (23:36:38.444 CallCtrl::eek:nIncomingCall [CM503001]: Call(3): Incoming call from Ext.101 to [sip:3493139351@192.168.0.12] ).
    Any other ideas? Tanks 1000!
  6. archie
    3CX Support
    Aug 18, 2006
    1,299
    Probably your outbound rule strips first digit, so GSM doesn't receive valid number and waits for additional input or something
  7. AndreaL
    Apr 24, 2008
    12
    No, the outbound roule strip 0 digits.
    For gateway configuration, I choose the "generic gateway device" option. Is that right?
  8. archie
    3CX Support
    Aug 18, 2006
    1,299
    Yes
  9. AndreaL
    Apr 24, 2008
    12
    Ok, now the Portech is running. The goal was to upgrade its firmware from march 2008 edition to may 2008 edition. The only problem remaining is that when a mobile phone is swithed off and i try to call it, 3cx do not know that the phone is off and continue making the calling tone "tooo, tooo"; but I will open a new post for this problem.
  10. igor.snezhko
    igor.snezhko Active Member
    Jan 7, 2008
    668
    7
    Hi!
    I fought 4 hours with Portech 370 and 3CX and cannot bring it to work. Them simply do not working together!
    I used Portech manual and 3CX Wiki.
    I have May 2008 Firmware at Portech and latest 3CX build (6.0.806.0)
    I configured Portech as decsibed at 3CX wiki. When I try to call from Extension to Portech I receive Busy Here signal
    When I call from GSM to 3CX I cannot get direct call transfer. I always receive dialtone so I need to dial any number to get "external" 3CX extenson.
    When I set Mobile to Lan route as stated in Wiki Im almays receive Busy signal.
    In short Portech does not work in both directions and I cannot figure the problem.I think I need to tweak some advansed 3CX SIP settings but I do not know which :? :? :? :(
  11. AndreaL
    Apr 24, 2008
    12
    Is the GSM service registered succesfully (see the GSM status)?
