Portech MV-374 no outgoing calls
Discussion in '3CX Phone System - General' started by amygoda, Oct 23, 2013.
  1. amygoda
    amygoda Member
    Sep 18, 2006
    436
    The device is registered and receive calls
    but no dial out
    23-Oct-2013 21:22:41.207 Leg L:37.1[Extn] is terminated: Cause: BYE from PBX
    23-Oct-2013 21:22:41.156 Leg L:37.2[Line:80861>>01122005555] is terminated: Cause: 408 Request Timeout/INVITE from local
    23-Oct-2013 21:22:41.154 [CM503020]: Call(C:37): Normal call termination. Call originator: Extn:70721. Reason: No answer
    23-Oct-2013 21:22:41.154 L:37.1[Extn] failed to reach Line:80861>>01122005555, reason No Answer
    23-Oct-2013 21:22:41.153 Call to T:Line:80861>>01122005555@[Dev:sip:80861@192.168.33.102:5060] from L:37.1[Extn] failed, cause: Cause: 408 Request Timeout/INVITE from local
    23-Oct-2013 21:22:41.153 [CM503003]: Call(C:37): Call to <sip:01122005555@172.17.99.201:5064> has failed; Cause: 408 Request Timeout/INVITE from local
    23-Oct-2013 21:22:28.499 Currently active calls - 1: [37]
    23-Oct-2013 21:22:08.978 [CM503025]: Call(C:37): Calling T:Line:80861>>01122005555@[Dev:sip:80861@192.168.33.102:5060] for L:37.1[Extn]
    23-Oct-2013 21:22:08.933 [CM503027]: Call(C:37): From: Extn:70721 (<sip:70721@172.17.99.201:5060>) to T:Line:80861>>01122005555@[Dev:sip:80861@192.168.33.102:5060]
    23-Oct-2013 21:22:08.933 [CM503004]: Call(C:37): Route 1: from L:37.1[Extn] to T:Line:80861>>01122005555@[Dev:sip:80861@192.168.33.102:5060]
    23-Oct-2013 21:22:08.933 Line limit check: Current # of calls for line Lc:80861(@MV374_01_L1[<sip:80861@192.168.33.102:5060>]) is 0; limit is 1
    23-Oct-2013 21:22:08.932 Call(C:37): Call from Extn:70721 to 86101122005555 matches outbound rule 'MV374_01_L1'
    23-Oct-2013 21:22:08.929 [CM503001]: Call(C:37): Incoming call from Extn:70721 to <sip:86101122005555@172.17.99.201:5060>
    10,586
    252
    Are you certain the destination and port number are correct?
    I'm seeing one public IP's but two different port numbers?
  3. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Hello Leejor,
    I tried to change ports in 3CX PSTN settings
    But before change it was the same problem
  4. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Is a way to choose the port for outgoing calls or it must be rounded
  5. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Hello Leejor,
    Thank you for your help
    I made each Line as a separate gateway
    in 3CX settings
    and now it works fine
  6. leejor
    10,586
    252
    I'm glad it worked out for you. I wasn't sure if you were using a gateway or a VoIP provider. A public IP usually indicate that an outside call is going to a VoIP provider, in which case you would usually be sending to one port, 5060 in most cases.
  7. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Hello Leejor,
    Is it possible to choose specified line in devices with 4 ports
    like Portech MV-374 Or Grandstream GXW-4104
    or it must be with 1 dial Plan and rounded
    also why 3CX remove grandstream and linksys and cisco from pre configured gateways
