Portech MV374 and 3CX v15.5
Discussion in '3CX Phone System - General' started by GabrielVE, Sep 5, 2017.
  1. GabrielVE
    Oct 25, 2016
    31
    Hi All,
    We're currently using a Portech MV374 GSM modem with 4 Sim cards that are configured to perform our Outbound calls.. Apparently we started encountering issues lately and wanted to recreate the gateways
    Apparently the said GSM modem is no longer listed as a supported GSM modem when creating a gateway, anyone who still have this modem and can help configure it to do outbound calls for 4 sims?
    Thanks,
  2. complex1
    complex1 Active Member
    Jan 25, 2010
    814
    49
