Portech re register
Discussion in '3CX Phone System - General' started by amygoda, Oct 25, 2011.
  1. amygoda
    amygoda Member
    Sep 18, 2006
    436
    After receiving any call portech does not re register
    I think it is because re register uses the phone called us (01121001004)
    15:49:04.687 Currently active calls [none]
    15:48:32.687 Currently active calls [none]
    15:48:00.687 Currently active calls [none]
    15:47:28.687 Currently active calls [none]
    15:46:56.687 Currently active calls [none]
    15:46:56.281 Blacklisted (Too many failed auth)IP = 10.99.99.108; Failed auth: 25; unauth: 25; auth: 26; 407: 0
    15:46:24.687 Currently active calls [none]
    15:46:07.406 [CM102001]: Authentication failed for SipReq: REGISTER 10.99.99.201 tid=35053b8504 cseq=REGISTER contact=01121001004@10.99.99.108:5062 / 29 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    15:45:52.687 Currently active calls [none]
    15:45:20.687 Currently active calls [none]
    15:45:07.015 [CM102001]: Authentication failed for SipReq: REGISTER 10.99.99.201 tid=0dcae15f81 cseq=REGISTER contact=01121001004@10.99.99.108:5062 / 28 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    15:44:48.687 Currently active calls [none]
    15:44:16.687 Currently active calls [none]
    15:44:06.609 [CM102001]: Authentication failed for SipReq: REGISTER 10.99.99.201 tid=767744f819 cseq=REGISTER contact=01121001004@10.99.99.108:5062 / 27 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    15:43:44.687 Currently active calls [none]
    15:43:12.687 Currently active calls [none]
    15:43:06.218 [CM102001]: Authentication failed for SipReq: REGISTER 10.99.99.201 tid=9af8b28e78 cseq=REGISTER contact=01121001004@10.99.99.108:5062 / 26 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    15:42:40.687 Currently active calls [none]
    15:42:08.687 Currently active calls [none]
    15:42:05.828 [CM102001]: Authentication failed for SipReq: REGISTER 10.99.99.201 tid=020fe60dce cseq=REGISTER contact=01121001004@10.99.99.108:5062 / 25 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    15:41:36.687 Currently active calls [none]
    15:41:05.421 [CM102001]: Authentication failed for SipReq: REGISTER 10.99.99.201 tid=1ff450b6d4 cseq=REGISTER contact=01121001004@10.99.99.108:5062 / 24 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    15:41:04.687 Currently active calls [none]
    15:40:32.687 Currently active calls [none]
    15:40:05.031 [CM102001]: Authentication failed for SipReq: REGISTER 10.99.99.201 tid=b35e313ee0 cseq=REGISTER contact=01121001004@10.99.99.108:5062 / 23 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    15:40:00.687 Currently active calls [none]
    15:39:28.687 Currently active calls [none]
    15:39:04.734 [CM102001]: Authentication failed for SipReq: REGISTER 10.99.99.201 tid=2ec9de574d cseq=REGISTER contact=01121001004@10.99.99.108:5062 / 22 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    15:38:58.671 Currently active calls [none]
    15:38:26.671 Currently active calls [none]
    15:38:04.343 [CM102001]: Authentication failed for SipReq: REGISTER 10.99.99.201 tid=4a56e0b154 cseq=REGISTER contact=01121001004@10.99.99.108:5062 / 21 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    15:37:54.671 Currently active calls [none]
    15:37:22.671 Currently active calls [none]
    15:37:03.953 [CM102001]: Authentication failed for SipReq: REGISTER 10.99.99.201 tid=85377ec0b2 cseq=REGISTER contact=01121001004@10.99.99.108:5062 / 20 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    15:36:50.671 Currently active calls [none]
    15:36:18.671 Currently active calls [none]
    15:36:03.546 [CM102001]: Authentication failed for SipReq: REGISTER 10.99.99.201 tid=d7c3e266ed cseq=REGISTER contact=01121001004@10.99.99.108:5062 / 19 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    15:35:46.671 Currently active calls [none]
    15:35:14.671 Currently active calls [none]
    15:35:03.156 [CM102001]: Authentication failed for SipReq: REGISTER 10.99.99.201 tid=1782bffcb8 cseq=REGISTER contact=01121001004@10.99.99.108:5062 / 18 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    15:34:42.671 Currently active calls [none]
    15:34:10.671 Currently active calls [none]
    15:34:02.765 [CM102001]: Authentication failed for SipReq: REGISTER 10.99.99.201 tid=fa4e931395 cseq=REGISTER contact=01121001004@10.99.99.108:5062 / 17 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    15:33:38.671 Currently active calls [none]
    15:33:06.671 Currently active calls [none]
    15:33:02.359 [CM102001]: Authentication failed for SipReq: REGISTER 10.99.99.201 tid=3b41fc7fe0 cseq=REGISTER contact=01121001004@10.99.99.108:5062 / 16 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
  2. complex1
    complex1 Active Member
    Jan 25, 2010
    764
    39
    I think it is more like a hardware problem. (PSU??)
    When you are being called the Protech tries to register itself with a wrong auth-ID or password.
    After 25 attempts its IP-address is blocked by 3CX.
    Are you running the latest firmware in your MV-37x?
  3. amygoda
    amygoda Member
    Sep 18, 2006
    436
    yes its 10.160
    and previous firmware 10.142 was doing the same
    I have 3 devices all of them doing the same issue
    this happen after the call end
  4. complex1
    Jan 25, 2010
    764
    39
    I am using a MV-370 with f/w 10.115 and PCB=2N149A
    There is an (new) setting “Restart dial fails” in Mobile >> Settings which I have set to 15.
    I think this is a kind of ring counter, after 15 rings -in this case- the portech restarts.
    Maybe your setting is less then 15, maybe 0 or 1?
    See also the manual (MV-37x) page 17, item 10 which says:
    “(10) Restart Dial Fail: In this feature, user can initialize and register the
    module while GSM module dials fail in couple times. When GSM
    module is dysfunctional, it can avoid the device shut down in
    advance.”
    Hope it helps.
  5. amygoda
    amygoda Member
    Sep 18, 2006
    436
    I Can receive calls
    but after any call received or missed
    re register work as you see
    restart dial fail = 1 (the default)
    I think it is re register using last called number as id which makes the registration fails
  6. complex1
    Jan 25, 2010
    764
    39
    One last thing: are your settings in 3CX all right?
    Please check the next settings
    PSTN Settings >> GSM-Gateway >> Inbound Parameters
    Call Source Identification
    - Matching Strategy: “Match All Fields”
    - “SIP Field” and “Variable” are empty
    Content of SIP fields
    - SIP Field: “Contact : Host Part”
    - Variable: “DevHostPort source address/port of message”
  7. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Yes it is as you mentioned
    I think it's from portech settings or firmware
    Thank You
