ports 9000-9040 closed on 3cx - remote phones wont work
Discussion in '3CX Phone System - General' started by twistedtech, Sep 27, 2011.
  1. twistedtech
    Sep 22, 2011
    ok, tried getting remote phones working -no avail......used softphone and can only connect via tunnel. Telnet remote AND local to IP 9000 doesn't get a response. On 3cx server if I run netstat, no ports opened past 5000. NOT a firewall issue, 3cx is not opening ports 9000-9049. HELP!!!!
  2. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    1) Your firewall has to have the ports opened and forwarded to the 3CX phone system box
    2) The Windows firewall has to have those ports opened
    So yes, one way or another it is most likely a firewall issue.
