Ports/Trunks Status Not Registered
Discussion in '3CX Phone System - General' started by Evulshot, Jan 15, 2018.
  1. Evulshot
    Jan 15, 2018
    Hello Everyone,
    Having a major problem. All 3 of my voip accounts are showing not registered. I did make a network change where the public IP has changed, but I did configure this in the settings. I've run the Firewall checker and all ports come back green and ready to go. Yet I still am unable to register with any of my providers.
    I am getting the following errors, has anyone seen this or have any idea what I am missing?
    15-Jan-2018 15:23:56.563 Dev(38):[sip:175793@toronto2.voip.ms:5080 / 175793]: (!) No transport is found for destination: <sip:mad:158.85.70.149:5080>
    15-Jan-2018 15:23:52.278 Dev(3):[sip:17778215247@callcentric.com:5060 / 17778215247]: (!) No transport is found for destination: <sip:mad:204.11.192.159:5060>
    15-Jan-2018 15:23:49.097 Dev(1):[sip:17772514503@callcentric.com:5060 / 17772514503]: (!) No transport is found for destination: <sip:mad:204.11.192.159:5060>
    15-Jan-2018 15:23:47.521 Dev(38):[sip:175793@toronto2.voip.ms:5080 / 175793]: (!) No transport is found for destination: <sip:mad:158.85.70.149:5080>
    15-Jan-2018 15:23:43.255 Dev(3):[sip:17778215247@callcentric.com:5060 / 17778215247]: (!) No transport is found for destination: <sip:mad:204.11.192.159:5060>
    15-Jan-2018 15:23:40.054 Dev(1):[sip:17772514503@callcentric.com:5060 / 17772514503]: (!) No transport is found for destination: <sip:mad:204.11.192.159:5060>
    15-Jan-2018 15:23:38.479 Dev(38):[sip:175793@toronto2.voip.ms:5080 / 175793]: (!) No transport is found for destination: <sip:mad:158.85.70.149:5080>
    15-Jan-2018 15:23:34.212 Dev(3):[sip:17778215247@callcentric.com:5060 / 17778215247]: (!) No transport is found for destination: <sip:mad:204.11.192.159:5060>
    15-Jan-2018 15:23:31.062 Dev(1):[sip:17772514503@callcentric.com:5060 / 17772514503]: (!) No transport is found for destination: <sip:mad:204.11.192.159:5060>
    15-Jan-2018 15:23:29.452 Dev(38):[sip:175793@toronto2.voip.ms:5080 / 175793]: (!) No transport is found for destination: <sip:mad:158.85.70.149:5080>
    15-Jan-2018 15:23:25.184 Dev(3):[sip:17778215247@callcentric.com:5060 / 17778215247]: (!) No transport is found for destination: <sip:mad:204.11.192.159:5060>
    15-Jan-2018 15:23:22.027 Dev(1):[sip:17772514503@callcentric.com:5060 / 17772514503]: (!) No transport is found for destination: <sip:mad:204.11.192.159:5060>
  2. mariosM_3CX
    mariosM_3CX Support Team
    Nov 1, 2017
    401
    36
    Hello @Evulshot
    Do you have your ip as static or dynamic in MMC >> Settings >> Network?
    Can you please do an nslookup of your FQDN and see if it resolves to the new IP?
  3. eddv123
    eddv123 Active Member
    Aug 15, 2017
    875
    131
    Hi Evulshot,
    If you want to change your public IP in 3CX and/or your nslookup is not resolving as it should you can get you public ip to change in 3CX's dns servers by:
    * navigating to Settings > network and switch to use 'Dynamic Public IP (IP changes)'
    * Restarting the services using the services.mmc.
    * Then wait 20 minutes and go back and switch back to ' Static Public IP (IP Address does not change)' and again restart services.
    It will take up to an hour to change on their systems DNS and then up to 6 or more hours to propagate around the internet.
  4. complex1
    complex1 Active Member
    Jan 25, 2010
    752
    38
    Please restart all 3CX Services, not the machine.
